Shelly button1 Action URL not working
  • I configured my Shelly button1 to use the Actions URL to be hit when the button is pressed short as follows;
    http://192.168.2.198:8123/api/webhook/201
    I'm using Home Assistant to receive this webhook call and have tested from the terminal of my computer using the following command;
    curl -X POST http://192.168.2.198:8123/api/webhook/201
    The command sent from the terminal of my computer works every time. When I press the button on my Shelly button1 it doesn't work.
    Current version: 20201124-092005/v1.9.0@57ac4ad8
    Shelly button 1 IP: 192.168.3.250/24 (Mask: 255.255.255.0, Gateway: 192.168.3.1)
    Computer IP: 192.168.3.232/24 (Mask: 255.255.255.0, Gateway: 192.168.3.1)
    Home Assistant: 192.168.2.198/24 (Mask: 255.255.255.0, Gateway: 192.168.2.1)
    Home Assistant OS 5.10
    core-2021.1.5
    Am I doing something wrong here?
    Thanks,
    Rob
    • Hilfreichste Antwort
    it's working from the computer because you send a HTTP POST request (curl -x POST...)
    Shellys can send only HTTP GET requests,
