Water Boiler - Shelly internal temperature
  • Hi
    I have successfully wired my Shelly 1PM to my 3KW solar heater
    However,
    shellies/shelly1pm-<deviceid>/temperature<br>
    reports the temperature of the Shelly at around 64 Celciu while running.
    I cannot seem to find any reference for the safe operating values of the shelly in internal temperature terms; Documentation only lists the tested environment temperatures (-40, 40 Celcius).
    Is it safe to operate with these temperatures? the Shelly is installed behind the wall switch.
    After an hour of operating, it doesnt seem to go more than that. Also, after an hour of operating and turning off it has dropped to around 30.
    Thanks!
    the internal temperature near the hottest point is measured. Your 64°C are not unusual and normal. Safety shutdown in case of overheating is at 95°C
