I got 2 shelly dimmers that updated to this firmware. However after turning on, it turns often off again. Am i the only one?
Same here. It goes into error state.
Seems deleting clibration and calibrating again should solve it.
I my case it did not but maybe I should try again.
Noticed that the dimmer level is very different from previous firmware which might explain the calibartion need.
I went back to previous firmware... everything works fine now again. Adressed the problem to Shelly...but seems no fix?
The shelly dimmer 2 seems to be pretty fragile apart from the fact that in general the overall level of testing of firmwares seems to be very poor.
Device offline many times back to 1.9.3 OK
