Switch doesn't work
VPN/Proxy detected
It appears that you are using a VPN, or proxy service. Please note that using such a service may limit the functionality of this website.
  • Hi,
    I just installed a Shelly 1L (it's my first one) on my kitchen lamp with N and L power.
    To the input switch 1 I put a Line Powered wire conneceted to standard on/off switch, I wired dozen of Shelly 1 like this one but with 1L I've got a very strange behavior.
    If I choose the "Toggle Switch" this happens:
    1. if I switch the lamp on via the Shelly panel the physical switch can turn lamp off after 2 clicks but can't turn it on
    2. if the lamp is off the physical switch doesn't do anything.
    If I choose the "Edge Switch":
    1. if I switch the lamp on via the Shelly panel and then I use the physical switch to turn lamp off Shelly starts to flash indefinitely
    I tried both "off" and "restore last mode" option but doesn't help.
    Anyone can help me?
    Thanks
    Gekomax
  • Jolly#Base#19453 January 17, 2021 at 8:11 PM
    Changed the title of the thread from “Switch doen't work” to “Switch doesn't work”.
