LocalActions not working when using Shelly as AccessPoint
  • Hi everybody,
    I'm using a brand new Shelly EM to control power consumption of oven / washing machine / boiler and avoid disconnection from the grid.
    I've read about the "Local" Actions and I was interested on them, because I haven't an internet connection at home - usually if needed, I use my smatphone hotspot..
    So I've connected for the first setup and for the firmware update the Shelly EM to my hotspot.
    After this I've started see the CHANNEL 1 (and 2) OVER POWER / UNDER POWER Actions.
    I've tried them by setting a threshold and by filling the "Url to be hit" fields with :
    http://localhost/relay/0?turn=off (when the power is over)
    and
    http://localhost/relay/0?turn=on (when the power is under)
    and everything worked fine! Good.
    BUT: if I set the Shelly EM as HotSpot (no more as Client Node), the Local Actions suddently stop working.
    I've tried changing the ip in the GET query (192.168.33.1 instead of localhost), and I've also tried to do a GET request in a local server, but it seems that the Shelly doesn't use at all the Local Actions when in HotSpot mode...
    Is it intentional, or a bug?
    Is there a way to fix this, and be able to use the Local Actions even if Shelly is not connected to a wifi?
    Thanks
    M
