Shelly Dimmer 2 and 2 way switch
  • Hello,
    I have a lamp which is controlled by 2 2-way switches and I would like dim/control the lamp also with a Shelly Dimmer 2.
    The dimmer 2 is already installed as described in the diagram.
    I can turn on / off the lamp with the switches and also with the Shelly app.
    Now the problem is when I turn on or off the lamp with the Shelly app, the first time when I toggle one of the switches, then lamp doesn't goes on or off.
    When I toggle the switch second time, the lamp goes on or off.
    The only settings I've changed in the Shelly app are Button type to "Toggle switch one button" and calibration to "trailing edge".
    What am I doing wrong?
    • Hilfreichste Antwort
    With regular wall switches you should change the Button Mode.
    Use Edge instead of Toggle ..
  • I have the same request but don't have the neutral.
    I tried to use the same scheme without neutral but it is not working.
    any idea?
  • Usually it is better to start a new thread if you have a different situation.
    Do you use the Bypass?
    If you don't have a Bypass the Dimmer2 needs at least 10W power consumption to work.
