Hi, have any of you used a Shelly 2.5 to control a bipolar switch? I am wondering if it is possible to use the two channels of a Shelly 2.5 to automate one single bipolar switch. The idea is to use one channel to interrupt the Phase and the other to interrupt the Neutral, and then to use both the channel as a group, at the same time, to activate or deactivate the bipolar switch. Is this possible? Does it make sense for you? Thank you for your answer.
