Shelly button1 wifi, problem with sleep mode ? OK when USB plugged
  • Hello,
    I made a scene WHEN the Shelly button is short pressed THEN turn on the light --> but it doesn't work when the button is not USB plugged
    When I plug the device, all is OK
    I have 4 buttons and the same problem with scenes --> the light is blinking and become green but no action on my lights/roller shutter...
    I have IOS app and the firmware is 20201029-170348/V1.9.0@85C87178 on wifi button devices
    Someone have a workaround ? or have the same trouble ?
    I'm sad because I bought 400 € of shelly's devices but I can't use them correctly
    May be a new firmware to correct potentialy sleep mode malfunction ?
    BR
    Nicolas
  • I have the exactly the same issue as detailed in my post on 6th Dec. On battery the button works ok to trigger single devices by url but won’t trigger scenes unless plugged into usb power. Not convinced its a sleep issue as it occurs as soon as the button is unplugged so doubt it has time to go to sleep.
