Hi! I have successfully installed 3 Shelly 2.5 but the fourth does not connect the defined router. Also the connection to 192.168.33.1 is very very unstable. Is this a hardware problem?
This can be.
You can try a hardreset. Sometimes, this fix wlan-problems of shelly.
power off
after 10 seconds powerv to the shelly
in first minute switch 5 times sw1 or sw2 (relais switch very fast = reset)
good luck. ![]()
