Shelly 1PM gets hot
  • Got two Shelly 1PM, flashed with tasmota, calibrated on 60W bulb, everything works.
    Week ago attached one to air conditioner which uses 1500W (7A):
    when off shelly temperature is 50-60c at 25c room temp
    when on shelly temperature gets to 75c after an hour and then heating cycle ends so shelly cools
    seems bit high but as long as it gets to 75c max I’m ok with it.
    Now attached one to water heater which uses 2600W (12A):
    when on shelly temperature gets to 90c after 20 minutes and turns off by itself.
    I’m using them only for monitoring power consumption not for controlling devices.
    Wired them both according to shelly instruction like this:
    What could it be source heating problem? 12A should be ok on 16A switch
    Einmal editiert, zuletzt von potat0 (3. Januar 2021 um 00:49)
  • potat0 3. Januar 2021 um 00:49
    Hat den Titel des Themas von „Shelly 1PM gets hot, wiring options?“ zu „Shelly 1PM gets hot“ geändert.
  • Gast10 3. Januar 2021 um 06:59
    Hat das Thema aus dem Forum Shelly 1PM nach Tasmota verschoben.
  • seems bit high but as long as it gets to 75c max I’m ok with it.
    Don't worry, 75 degree Celsius is the internal temperature (MCU) which is absolutely ok ..
    Shelly1PM automatically turns off if a critical temperature is reached (which is IIRC around 95 degree celsius)
    this is the self protection mentioned above.. the issue is probably related to the place where the Shelly is installed.. a closed box? then there is no air circulation which increases the temperature over the time..
    Maybe you can install inside a bigger box or with some distance to other devices, which may affect the temperature?
    Einmal editiert, zuletzt von Seven of Nine (3. Januar 2021 um 07:57)
  • Don't worry, 75 degree Celsius is the internal temperature (MCU) which is absolutely ok ..
    Yes it's in very tight and closed box and there is no possibility for better place
    These devices supposed to be in such places I think, and still it's only 12A from 16A
    Maybe tasmota firmware has something to do with it, later I'll reflash them and try with original firmware
    From your signature you have tons of Shellys, did you try one of them under load of more than 10A for long period of time, at least an hour?
  • From your signature you have tons of Shellys, did you try one of them under load of more than 10A for long period of time, at least an hour
    not a 1PM, I use those only for lights.. ShellyPlug for my washing machine, Shelly EM for the Dryer, Shelly4Pro for the oven and fridge.
    yes, you should definitely test with the stock firmware ..
  • My 1PM on stock firmware running a 3kW immersion heater in a closed box approaches 85°C reported temperature after half an hour or so, at which time the immersion heater turns itself off: the Shelly doesn't trip itself.
    I doubt this is firmware-related: it's probably just the combination of the I²R heating of the power measurement circuit and the ventilation situation.
