False trigger events
VPN/Proxy detected
It appears that you are using a VPN, or proxy service. Please note that using such a service may limit the functionality of this website.
  • Hi,
    I have an issue with dimmer2. I get false events fired (possibly because of noise on the electricity grid).
    I use MQTT to controll the shelly devices.
    I have button type setup as detached and use 0-input to detect state changed from the connected switch. Based on that event I switch the dimmer2 and a bunch of ther shellys on or off.
    At random times during the day the 0-input event is fired without the switch actually being touched.
    The effect varies with various firmware versions. Also played with button debounce settings but I cannot get rid of these false triggers. A shelly dimmer (1) in the same setup does not have this issue.
    Any ideas?
  • possibly because of noise on the electricity grid)
    this.. I'd assume there's some kind of temporary inductive load (sw input) which causes the issues..
