Enable for 3 minutes on long press with 1PM
  • Hi. My first post here , so hello everyone!
    I have a 1PM connected with momentary switch. Simple on/off for garage lights. All working fine.
    Now I would like to use LONG PRESS to enable it just for 3 minutes.
    Tried to do it with long press url.
    URL is working - tested from chrome
    long press action is working - I can turn on other shelly , but I can't use it on the same device.
    What's the best way to do it ? Is it even possible ?
  • Hello Daniel,
    sorry for the delay - I did some tests to figure out how to solve your idea.
    I was not succesful.
    To control another Shelly with short/longpress by using URLs is no problem.
    These URLs run perfect:
    http://IP-of-shelly/relay/0?turn=toggle (short)
    http://IP-of-shelly/relay/0?turn=on&timer=180 (long)
    The same shelly (independent if the configuration is momentary or detached) shows no reaction.
    It seems, the actual firmware does not support sending an URL-command to itself and receive/response corresponding.
    Have you already tested with scenes?
    Viele Grüße,
    Wolfgang
    • Hilfreichste Antwort
    For adressing the own ip, you have to use "localhost".
    http://localhost/relay/0?turn=toggle
    Welcome to the forum @Daniel Czechowski :)
  • Have you already tested with scenes?
    Well . I did now , after your comment ! Not sure why I was fixed on this URL and did not try it earlier.
    Thank you!
    Working without any problems.
    Action are:
    If light is OFF and long press => turn on AND turn off after 5 min
    second one
    If Light is ON and long press = > turn off after 5 min
