Push button for Led driver/dimmer
  • Hello,
    I have led spots in my bathroom, controlled by a Hidealite Jolly Maxi US. The dimmer function of the driver is controlled by a push button (spring back) on the wall. Push the button fast for on/off, and hold the button in for dimming.
    Is there a shelly device I can add between the physical button and the led driver/dimmer that can simulate the push button (push once and hold in) as well as throughput the physical button?
    Because the working voltage is 110 or 230V it can be done by an 2.5
    Example
    Channel 1 with Auto off 1 sec.
    So you can turn on/ off
    Channel 2 as dimmer function
    Here you need to push two times.
    First for on and second for off (output)
