I have different shelly dimmer 2. At a low dimming level there is no current measurement. The power measurement does not go lower than 2.57 watts, if I dim even more then the power measurement will be 0 watts. Is this normal behavior for shelly dimmers?
No current measurement at low dimming level
- Shelly Dimmer
froggykwak -
22. Dezember 2020 um 23:17 -
Erledigt
- Offizieller Beitrag
Hi and welcome to the forum.
I"ve checked my dimmer2 right now and in low level, there is 0W shown at 10%.
I haven't even noticed that because I don't base my lighting on consumption, but on demand.
Is this a technical limitation of the shelly dimmer 2 or is this something that can be adjusted in the shelly software?
In the current statistics no value is displayed even though I have the lighting on at a minimum at night.
Only the manufacturer can answer that with absolute certainty.
You can open a ticket at Allterco.
I filed a ticket to Shelly support. Tnx for your response.
Dieses Thema enthält 2 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
