No neutral shelly L1?
  • With shelly L1 If you need a bypass to connect to neutral just on a different port. Why claim control without neutral?! What is the difference?
  • That doesn't answer my question with or without a wink!
    If you need to connect to a neutral line, be it through a different port with a bypass, you still need neutral.
  • Since you haven't actually explained anything but just expressed your opinion.
    I would have to wait for an explanation! Which, most likely, won't be coming since the claim about control without a neutral wire are baseless! At least it seems so at the moment.
