192.168.33.1 not reachable
  • So I've bought a whole lot of 1 & 2.5's.
    Most of them work properly, but I cannot get some of them initiated properly.
    Some of them failed to be initiated via the iOS Shelly app. So I stopped using the app. Instead I've added all other Shelly's by connecting to the builtin AP using a laptop. Shelly hands out a DHCP ip 192.168.33.2/24 and is configurable on http://192.168.33.1. Following this method proved to be working perfectly.
    BUT... The Shelly's which failed to be initiated via the Shelly app keep giving me headaches.
    I've resetted them using the 5-ON/OFF-switch method (I can hear the relays ticking fast to confirm the reset). They broadcast as AP again, but:
    • Some hand out the DHCP 192.168.33.2 address, but I cannot connect to the http://192.168.33.1 page
    • Some don't even hand out an IP when connecting to it. I end up with a self assigned IP address, and cannot connect to http://192.168.33.1.
    I've tried resetting them, multiple times. But this doesn't seem to fix anything.
    Any ideas?
    Kind regards
    Martijn
  • Heya,
    This thread is quite old, but I had the same problem and for whatever reason using my phone I could not access 192.168.33.1 while to connect to a H&T sensor own Wifi. I reset it multiple times and still nothing.
    But, as soon as I used my computer to connect to 192.168.33.1 suddenly I could get in and configure it for my home's wifi.
    Hope it helps someone.
