I have 2 toggle switches (not momentary switches) which I want to connect to SW1 and SW2.
Both should be able to control Relay 1.
Relay 2 can be disabled (it will not be used).
But I'm not able to get this to work. Any ideas?
why don't you connect both switches to SW1?
can you explain to me more exactly what you want to switch?
They're not momentary switches, but toggle switches.
Meaning that if I connect 2 switches to a single SW input, I might still get power on the SW input when I toggle one of the switches, because the other switch is still turned ON.
Hey can you show a wiring diagram.
Or make some pictures and explain where what is.
And what isn't working?
Is the shelly ok but the switches makes problems? Or isn't the shelly working?
Below the wiring scheme
The toggle switches should both be able to control the 01 output.
Edit by 66er:
Attention:
This scheme is wrong and does not work!
Since the output switches the phase, the lamp must be connected to N instead of L.
