Hi.
There's any way to improve a Shelly 1 wi-fi range?
Can i solder any exterior antena to the device? If yes where?
Regards
Hi.
Regards
No,
in case of 230V using, this is connected to antenna!
Danger for life!
An additional repeater is the better choice.![]()
The shelly stays blocked inside a box on the wall so i will not touch any wire.
That doesn't change anything, because at the latest when you have to get to the Shelly, the danger is back.
Only the manufacturer knows why this is so.
Don't do it!
