Dimmer 2 overtemperatured with 2 halogen r7s 100W
  • I've exchanged a normal dimmer with a Shelly Dimmer2.
    Connected without neutral and with a standard on/off switch.
    The Dimmer 2 overheat very quickly and can only be used on 32% and max 76W.
    Dimmer is calibrated on leadingedge. (Same problem on trailing edge)
    Is 2x100Watt halogen r7s to much for this dimmer?
    {"wifi_sta":{"connected":true,"ssid":"****","ip":"192.168.178.194","rssi":-55},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"10:42","unixtime":1607856165,"serial":1892,"has_update":false,"mac":"*******","cfg_changed_cnt":6,"actions_stats":{"skipped":0},"lights":[{"ison":true,"source":"cloud","has_timer":false,"timer_started":0,"timer_duration":0,"timer_remaining":0,"mode":"white","brightness":32}],"meters":[{"power":76.20,"overpower":0.00,"is_valid":true, "timestamp":1607856165,"counters":[76.329, 76.339, 76.290],"total":34033}],"inputs":[{"input":0,"event":"L","event_cnt":6},{"input":0,"event":"","event_cnt":0}],"tmp":{"tC":95.66,"tF":204.18, "is_valid":true},"calibrated":true,"calib_progress":100,"calib_status":0,"wire_mode":0,"overtemperature":false,"loaderror":0,"overpower":false,"debug":0,"update":{"status":"idle","has_update":false,"new_version":"20201124-092706/v1.9.0@57ac4ad8","old_version":"20201124-092706/v1.9.0@57ac4ad8","beta_version":"20201202-141422/v1.9.3-rc3@50c6ab57"},"ram_total":48368,"ram_free":35192,"fs_size":233681,"fs_free":113703,"uptime":89336}
    Einmal editiert, zuletzt von Steep#Fog#21437 (14. Dezember 2020 um 08:39)
  • Steep#Fog#21437 13. Dezember 2020 um 10:48
    Hat den Titel des Themas von „Dimmer 2 overheated with 2 halogen r7s 100W“ zu „Dimmer 2 overtemperatured with 2 halogen r7s 100W“ geändert.
  • Teoretically it should handle 200W.
    I suspect the lamps are connected in series, could you please check it?
    They should be connected in parallel.
    As a side note, R7S LED lamps already exist.
    Einmal editiert, zuletzt von BSoft (13. Dezember 2020 um 18:51)
  • They are connected parallel. Led version are ordered and I hope they will do the job.
    I need real 360 led r7s .
  • Overheat at 76W with a pure resistive load is not normal and i would expect dimming at near 0%.
    If i was you i consider returning the shelly.
    Until then, check with only one lamp (calibrate -> reboot -> calibrate), and previous firmwares.
    Einmal editiert, zuletzt von BSoft (14. Dezember 2020 um 00:00)
