Door/Window 2 sensor has became offline after disabling Cloud access
  • Hi,
    I will like to access my Door/Window 2 sensor only when connected to my LAN, so I disabled Cloud access on it. The issue is that device has became offline on iPhone app after disabling Cloud access, even though I can access device via web browser. Door/Window sensor has static IP addressing and has been updated to the latest firmware version.
    Beside from this issue, device is working fine.
    I´ll appreciate any help on this, thanks.
    Hi raulrivas , welcome to the forum. :)
    unfortunately it doesn't work the way you want it to.
    For a purely local operation, you need a higher-level system for the DW. The DW is only online when he has something to say, otherwise offline (in sleep mode). ;)
