Noob question: I have a one switch for 3 different light bulbs in different places, switch does not have neutral wire. Will it work with Shelly L?
Noob question: I have a one switch for 3 different light bulbs in different places, Will it work?
- Shelly 1L
Long#Sky#21082 -
8. Dezember 2020 um 22:07 -
Erledigt
most likely yes
Do you know how to count nessesary load? If its 20, is it ok to have 3x7,5W LED? Is it ok to have 3x5W + 1 bypass or every bulb should have a bypass?
Yes, 3x 7,5W should be fine.
If a bypass is required, then one in total is sufficient, you don't need to connect one to every bulb!
I have a huge problem how to install bypass. I've installed like im connecting both Load and Live but doesn't seem to be working...
Also, how much energy bypass consumes?
Dieses Thema enthält 5 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
