Shelly Button 1 to Trigger Scene.
  • I can get my Shelly button 1 to trigger a Shelly relay from a url setup from within the app, this works fine if the button is connected to either power or battery.
    I can get the button 1 to trigger a scene (setup
    within the app) which works ok when connected to power. However, as soon as I disconnect the button from power and use battery, the button does not trigger scenes.
    What I’m I doing wrong please ?.
    I’ve tried the latest current & beta firmware both give the same results.
  • The December version IOS version of the Shelly App seems to have removed to ability to create new or edit existing scenes that are invoked from a Button 1. I have created a support ticket and they acknowledged the issue (so presumably they will fix it) but have suggested for now I use url commands.
    This works for other Shelly devices but is somewhat limiting.
  • The IOS app has been fixed but I still have the issue from the first post in this thread - Button 1 won’t trigger scenes while powered only by its battery.
