Shelly1 - SW entry - MQTT
  • Hello !
    First sorry for my english, i'm not fluent ;)
    I have a shelly1 connected on MQTT. It works perfectly using HomeAssistant or the GUI in order to switch on / switch off a light. MQTT is corretly configured because i can see the state of the shelly (relay topic on/off).
    I would like to have the value of the entry "SW" into MQTT or HA. this entry SW is connected to a toggle switch, in order to switch on / switch off the light . You can see the connections above :
    The button type is configured as "toggle switch" in the GUI of the shelly1. The firmware update is the last beta 20201202-135844/v1.9.3-rc3@50c6ab57. But when i'm using the toggle switch, the topic shelly1/input is allways on value "0=1", whatever the toggle switch was on or off.
    Externer Inhalt ticket.shelly.support
    13802-capture-d-%C3%A9cran-2020-12-05-103531-jpg
    The automation i want to do : if the switch is "on" for 60s, then switch on the light. So this SW entry needs to be "detached".
    Have you an idea for what's wrong ?
    Thanks
