Beta 1.9.3
  • Moin,
    ich bekomme auf meinen Shellys bei der FW folgendes angezeigt: New BETA version: 20201202-141212/v1.9.3-rc3@50c6ab57 is available.
    Hat die jemand installiert? Gibt es da Info ? Hab hier im Forum nichts gefunden.
    viele Grüße
    Michael
    von Facebook kopiert:
    BETA firmware 1.9.3_RC3 are released. It's stable to be used for anyone who has a these issues:
    (Please report also what AP are you use)
    Update: All devices (excluding battery powered)
    Slow reaction from cloud, Alexa or Google home. Frequently cloud disconnecting. HomeAssitant, OpenHab, Homey and other 3-th party integration: Unstable connection and delay responses over CoAP
    Shelly 2.5
    We have log from some costumers and found the issue with disconnects (it's happens with some routers): Device is kick out from the router and when try to connect again SDK return Authorization problem, even everything is ok.
    We proceed to update SDK to Tuesday and release new version. But today we will prepare a version which detect that issue and reboot device (will be option in internal WebUI).
    Shelly Bulb Sunrise and Sunset scheduling do not change brightness is fixed
    Shelly Dimmer1 and Dimmer2
    Light is switched off and overpower message appear or there is no error message - fixed.
    How to update: Open device by IP. Update it from Settings -> Firmware update. You can revert it anytime. Comments Rules: All comment which is not related with this BETA firmware to reporting results or issues will be deleted.
    ich habe leider auch weiterhin Verbindungsabbrüche mit der RC3, die nur mit Spannung abschalten und reboot zu beheben sind. Am stabilsten läuft immer noch die shelly Firmware 1.8.X, aber auch da, wenn auch seltener Abbrüche.
    Verbindung über Unify Access points (Unify 4x FlexHD und 1x UDMBase)
    UDMBase Firmware 1.8.3
    FlexHD Firmware sämtliche 5.xx.xx Versionen probiert.
    mit sämtlichen einstellungsvarianten hier aus dem Forum Thread zum 1.9 Update ausprobiert.
    Result vom /Status:
    {"wifi_sta":{"connected":true,"ssid":"XX","ip":"10.XXX.XXX.XXX","rssi":-51},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":true},"time":"09:58","unixtime":1607248719,"serial":8,"has_update":true,"mac":"68C63AXXXXX","cfg_changed_cnt":2,"actions_stats":{"skipped":0},"rollers":[{"state":"stop","source":"input","power":0.00,"is_valid":true,"safety_switch":false,"overtemperature":false,"stop_reason":"normal","last_direction":"open","current_pos":100,"calibrating":false,"positioning":true}],"meters":[{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":1607248719,"counters":[0.000, 0.000, 0.000],"total":0},{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":1607248719,"counters":[0.000, 0.000, 0.000],"total":0}],"inputs":[{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"temperature":37.47,"overtemperature":false,"tmp":{"tC":37.47,"tF":99.44, "is_valid":true},"temperature_status":"Normal","arpchk_resets":8,"arpchk_results":1,"update":{"status":"pending","has_update":true,"new_version":"20201128-102046/v1.9.2@e83f7025","old_version":"20201202-140039/v1.9.3-rc3@50c6ab57","beta_version":"20201202-140039/v1.9.3-rc3@50c6ab57"},"ram_total":49000,"ram_free":33756,"fs_size":233681,"fs_free":122739,"voltage":229.15,"uptime":250}
    Viele Grüße
    Downset
