SH1 with add-on thermal sensors board
  • Hi, does someone has tried to connect SH1 powered at 12v DC to thermal add-on board ?
    I've tried with two SH!, two different boards, two different probes with the same bad results.
    After initial boot SH1 loose the AP's connection, start heating excessively, start to burn
    smelling smoke. After several tests I presume add-on board is not compatible with SH1
    but there is nothing written about this.
    Thank you
  • Thank you.
    Tis is the wiring and result of earlier and last test (using SH-A and SH-B) different units
    Externer Inhalt ticket.shelly.support
