Support for Allterco
    • Autor
    Hello Shelly Community,
    Allterco needs support from the community, but that only applies to affected customers.
    In order to fix the error (Shelly devices go offline) Allterco needs the following information from you:
    Which devices go offline sporadically?
    Your mask to fill out:
    • Shelly Typ:
    • Device Mode (if Shelly Type is Shelly 2.5 )
    • Firmware Version:
    • Router or AccessPoint:
    • Static IP or DHCP:
    Example answer 1:
    • Shelly Type: Shelly Plug S
    • Device Mode (if Shelly Type is Shelly 2.5) :
    • Firmware Version: 1.9
    • Router or AccessPoint: Fritzbox 7590
    • Static IP or DHCP: static IP
    Example answer 2:
    • Shelly Type: Shelly 2.5
    • Device Mode (if Shelly Type is Shelly 2.5) : Shuttermode
    • Firmware Version: 1.83
    • Router or AccessPoint: AP Ubiquiti
    • Static IP or DHCP: DHCP
    NOTE: This is not a discussion thread, all posts that do not relate to this specific question will be deleted.We don't want to discuss, we need a clear overview so that we can transmit or provide the data to Allterco.
    • Device Mode (if Shelly Type is Shelly 2.5) : Relay
    • Firmware Version: 1.9.2
    • Router or AccessPoint: ZYXEL VMG8825-T50 (By T-Mobile NL)
    • Static IP or DHCP: Static IP
    I also have 2 Shelly 1's, but they never stay disconnected. They always reconnect after a couple of seconds.
    • Router or AccessPoint: AP Ubiquiti: UDM + FlexHD
    I have 17 Shelly 2.5 in Shuttermode, all with the above configuration. Only 5 of them lost the IP (always the same devices and still visible in Unifi panel), they only connect again after a power cycle. Signal strength is good.
    • Shelly Typ: Shelly 1PM, Shelly 2.5, Shelly Dimmer 2
    • Device Mode: 2.5 is in shutter mode
    • Router or AccessPoint: Ubiquiti USG and Unifi AP AC Lite
    Since updating to 1.9.2 all my devices are losing connectivity after some time. Reconnect from the Unifi panel brings them back. I started testing 1.9.3-rc3. It seems better, but I'm not sure (needs more time).
    • Shelly Typ: Shelly 2.5
    • Device Mode: Relay
    • Firmware Version: 20201128-102046/v1.9.2@e83f7025 AND 20201216-140131/v1.9.3-rc4@146c9bd7
    • Router or AccessPoint: Unifi UDM Pro - latest firmware
    • Static IP or DHCP: Static IP, and I've tried turning off the DHCP server for the entire VLAN
    • I have ~30 Shelly 2.5 and I get about one disconnect per day. The only way to reconnect is to kill power to the Shelly
  • Dieses Thema enthält 56 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
