Shelly 1L I/O URL actions (control Domoticz virtual switch)
  • Hi,
    I have a small home-project where I have several Shelly switches, Xiaomi motion, humidity and temperature sensors, irrigation system and cameras. All controlled by Domoticz runs on a Raspberry pi. And here comes the issue. The status of the switch does not change on the UI of Domoticz if I switched it physically. I know that there is an "I/O URL actions" section in Shelly App, however it cuts the URL for some reason.
    Expected URL (sample): h t t p : // IP:PORT/json.htm?type= command& param=udevice &idx=89&nvalue=0 &svalue=Off
    Result in Shelly App after saving h t t p : // IP:PORT/json.htm?type=command
    Any suggestion maybe?
    Thanks, JdM
