Shelly Dimmer 2 - Wiring with two way switches and without neutral
  • Hi,
    I would like to install the [product]Shelly Dimmer 2[/product] :
    1. behind two way swiches (2 interrupteurs va-et-viens in French ;)).
    2. without neutral.
    You could find current wiring diagram in hereafter.
    I searched everywhere (shelly docs, forums....), and i did not find how to wire the dimmer in such a configuration. Is it possible (certainly with ByPass) ? what is the wiring diagram ? where i can find it ?
    Thanks in advance,
    Fabrice
  • Edit: See the next post for an easier way than described in this post.
    If you change the 2 way switches to regular 1 way than you can use the existing two wires between them to send L from the Switch 1 location to the Switch 2 location.
    And the L' going from the Switch 2 location to the Switch 1 location.
    This would give you the possibility to add a Dimmer 2 at the Switch 2 location.
    No the part I don't know if it is possible is a adding a second device because they would both use the same bypass.
    If it is possible than you can add a 1L at the Switch 1 location as you now have both L and L' at that location too.
    The 1L would get the switch input and would execute an API HTTP request (configurable under Actions) to the Dimmer 2 and hence controlling the light.
    Einmal editiert, zuletzt von torusJKL (5. Dezember 2020 um 07:13)
  • There might be an even easier way.
    Like with the previous solution use regular 1 way switches at both locations.
    Use 1 wire between the locations to forward L from location 1 to location 2.
    And use the other wire as the output from the switch in location 1 and connect it together with the output of the switch in location 2 to the SW1 input of the Dimmer 2 that is also located at location 2.
    See attached diagram.
  • I have done this from this site and works great:
    Einmal editiert, zuletzt von Admin (17. Mai 2024 um 10:56) aus folgendem Grund: Markenrechtsverletzung Bild gelöscht
  • Dieses Thema enthält 29 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
