Shelly 1L flickering LED bulbs
  • Dear all, I just joined recently, sorry if my question raised already. Anyways, I just installed 3 Shelly 1L switches and the lamps attached flickering in two cases, do not switch down fully (light faintly) and the switches are not available. I have to switch the button manually on/off to get the connection back.
    Connected leds: kanlux cold white 3w GU10, 3 circuits as 10pcs, 4pcs, 5pcs.
    Bypass installed in all cases.
    FW version: 20201128-101933/v1.9.2@e83f7025 the latest, I believe. Any ideas, thoughts, suggestions?
    Thanks, JdM
  • Same problem here. On top of that, they interfere with one of the bulbs in different room causing flickering
  • The same problem here. Shelly 1l switch, flickering when set to off or very faint light. Firmware instaled latest 20201228-92147/v1.9.3@ad2bb4e3. Also tryed with beta version of firmware, but not good at all.
  • The same problem here: same flickering when switch off, Bypass installed, firmware updated by app
    tried different type of GU10 led :
    3 x 5 w = all 3 lights flicker
    2x10w 1X5w = 5w fast flicker
    2x10w 1x.7.5 = 7.5 weak slow flicker
    with 3x10W could I solve the problem or will I still have the flickering?
    thanks
    Ale
    AleAle99
