MQTT Einbindung UNI
    leider finde ich kein Template für den Uni.
    Ich habe das Device am Laufen und kann die Kanäle schalten.
    Aber immer nur einen einen.
    Wie spreche ich den Kanal 2 an? Ich möchte gerne die Funktion "on-for-timer" behalten, da ich ihn als Taster für das Garagentor nutzen möchte.
    VG
    defmod Garage_door_CTRL MQTT2_DEVICE
    attr Garage_door_CTRL DbLogExclude .*
    attr Garage_door_CTRL IODev MQTT2
    attr Garage_door_CTRL autocreate 1
    attr Garage_door_CTRL devStateIcon {my $onl = ReadingsVal($name,"online","false") eq "false" ? "rot" : ReadingsVal($name,"new_fw","false") eq "true" ? "gelb" : "gruen";; my $light = ReadingsVal($name,"state","off");; my $show = '<a href="';;$show .= $onl eq "gelb" ? "/fhem?cmd.dummy=set $name x_update&XHR=1\">" : "http://%22.readingsval(%24name,%22ip%22,%22none%22).' "target="_blank">';; $show .= FW_makeImage("10px-kreis-".$onl)."</a>";; "<div> $show <a href=\"/fhem?cmd.dummy=set $name toggle&XHR=1\">".FW_makeImage($light)."</a></div>" }
    attr Garage_door_CTRL model shelly1
    attr Garage_door_CTRL readingList shellies/shellyuni-483FDA82C4A2/relay/0:.* state\
    shellies/shellyuni-483FDA82C4A2/relay/0:.* relay0\
    shellies/shellyuni-483FDA82C4A2/input/0:.* input0\
    shellies/shellyuni-483FDA82C4A2/relay/1:.* state\
    shellies/shellyuni-483FDA82C4A2/relay/1:.* relay1\
    shellies/shellyuni-483FDA82C4A2/input/1:.* input1\
    shellies/shellyuni-483FDA82C4A2/online:.* online\
    shellies/shellyuni-483FDA82C4A2/announce:.* { json2nameValue($EVENT) }\
    shellies/announce:.* { $EVENT =~ m,..id...shellyuni-483FDA82C4A2...mac.*, ? json2nameValue($EVENT) : return }
    attr Garage_door_CTRL room 1 Overview,MQTT
    attr Garage_door_CTRL setList off:noArg shellies/shellyuni-483FDA82C4A2/relay/0/command off\
    on:noArg shellies/shellyuni-483FDA82C4A2/relay/0/command on\
    x_update:noArg shellies/shellyuni-483FDA82C4A2/command update_fw\
    x_mqttcom shellies/shellyuni-483FDA82C4A2/command $EVTPART1
    setstate Garage_door_CTRL on
    setstate Garage_door_CTRL 2020-11-27 13:13:33 attrTemplateVersion 20200831
    setstate Garage_door_CTRL 2020-11-30 09:56:04 fw_ver 20200826-111450/1206-production-ShellyUNI@a80ee1fc+
    setstate Garage_door_CTRL 2020-11-30 09:56:04 id shellyuni-483FDA82C4A2
    setstate Garage_door_CTRL 2020-11-30 10:06:24 input0 0
    setstate Garage_door_CTRL 2020-11-30 10:06:24 input1 0
    setstate Garage_door_CTRL 2020-11-30 09:56:04 ip 192.168.178.231
    setstate Garage_door_CTRL 2020-11-30 09:56:04 mac 483FDA82C4A2
    setstate Garage_door_CTRL 2020-11-30 09:56:04 model SHUNI-1
    setstate Garage_door_CTRL 2020-11-30 09:56:04 new_fw false
    setstate Garage_door_CTRL 2020-11-30 09:56:04 online true
    setstate Garage_door_CTRL 2020-11-30 10:06:24 relay0 off
    setstate Garage_door_CTRL 2020-11-30 10:06:24 relay1 on
    setstate Garage_door_CTRL 2020-11-30 10:06:24 state on
  • Könnte ein Mod das nach FHEM verschieben? hat ja eher weniger mit MQTT als mit dem nicht vorhandenen FHEM-Template zu tun..
