How to connect external switch add-on shelly 1
- Shelly 1
sergiomfh -
25. November 2020 um 22:42 -
Erledigt
Hello I have the same question. Did you managed to find how to do it?
- Offizieller Beitrag
Hi and welcome to the forum.
Thank you! So there is no way to connect an external switch without using the add-on?
If you don't need a switch to switch the shelly, you can set the switch input to "detached".
So you can use the pin SW for an other task.
Dieses Thema enthält 9 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
