Tech Spec ?
  • The tech spec gives the following details:
    • Dimmable LED : 50-200VA / 1W – 200W
    • Resistive-inductive loads ferromagnetic transformers: 50-150VA
    I have found a 12V LED and associated dimmable LED driver that would look great in a highly visible location and I also want to dim it. No question about the software functions but rather can dimmer2 be used successfully on the 240VAC side of the LED driver.
    The LED in question power consumption is 3.5 Watts, I may have to install 2 LEDs to get the brightness I need but Im currently basing my assessment on just one.
    Given the min load in shelley 2 is spec'd as 1 W will I be able to dim the light and to roughly what percentage of the max output without flickering etc.
    Tks in advance.
