Clamp connector
  • Hi,
    I purchased new 50A clamps to connect to Shelly 3EM since the 120A were to big to fit inside my electrical board.
    But the 50A clamp does not have the connector at the end of the cable as the 120A has. It ends with two wires.
    Does anyone knows what type of connector is that so I can try to buy some?
    Thanks
  • The 3EM‘s clamps are said to be fine tuned to give the most precise readings possible, and that’s per line (A, B, C). Even if you were to fit your new clamps with the plugs from the old clamps (which I absolutely wouldn’t recommend doing), you‘re very likely to get useless results as the 3EM has, unlike the Shelly EM, no possibility to adapt to the 50A clamps.
    Best,
    Georg
