Difference between Shelly 1 and Shelly 1L?
  • Hi all, is there a place to see a comparison between the functional and technical details of the Shelly 1 and Shelly 1L? I bought my first Shelly 2.5's and installed them with my roller shutter system and now I am looking to expand to control some simple lights. I almost bought some Shelly 1's but saw that the Shelly 1L's are recently released but am not sure if I should go ahead with buying Shelly 1s or buy the new Shelly 1L's.
  • Hi!
    The main difference between the two shellys are:
    Shelly 1L: No neutral required
    Power on the device and control your light, fan, or other appliances only by Live wire, no neutral required to be connected to the device.
    Shelly 1:
    Higher load (16 A), and dry contacts (the switched relay is independent from the supply current).
    For switching lights on and off, the shelly 1 is best in most of the cases.
    Meine Shellys: 2.5, H+T, Shelly1, Shelly1Plus, Dimmer2, 1PM, 1PM Plus, Button1, i3, Bulb GU10, H+T Plus, TRV
    Weissnichtwieviele Intertechno Funksteckdosen und anderes 433 MHz Zeugs, Thermo/Hygro Funk-Sensoren von Oregon Science, alles gesteuert von einem übergeordneten System (LightManager Air) von JB media.
  • You are welcome!
    If you need more information, the guys here in the forum are very friendly and helpful.
    A bit more info from the shelly site:
    https://shelly.cloud/knowledge-base/devices/shelly-1
    https://shelly.cloud/knowledge-base/devices/shelly-1l
