Shelly 2.5 controlling motors with reverse polarity
  • Hi everybody.
    Have to control a Somfy 24vdc motor that works reversing polarity for closing or open. I mean... if connect +24v to A motor wire and -24v to B motor wire the motor opens but if connect +24v to B and -24V to A the motor closes.
    Solved it with 2x24v relays but would like avoid external relays and just using Shelly 2.5
    Does anyone knows if Shelly can be configured for switching polarity between 01 and 02 sockets ??
    Thanks ind advance
  • frankyglobal 15. November 2020 um 12:23
    Hat den Titel des Themas von „Sehelly 2.5 controlling motors with reverse polarity“ zu „Shelly 2.5 controlling motors with reverse polarity“ geändert.
  • Any chance to get a wiring diagram for this?
    Also, can these relays be controlled by the Shelly 1 or we need the 2.5?
    Thank you!
