Was looking in datasheets of shelly products but could not find, how would be possible to control light with both Line and neutral disconnected when is off.
Most of them is only single relay, or duoble relay, but double switches.
Thank you
Thank you
Nobody?
Hi tdigsi , welcome to the forum.![]()
If a Shelly is de-energized, you cannot switch it.
Also there isn't a Shelly product witch can handle this.
There are some possibilities.
1. You can make N permanent connected and switching only L
2. You have to use two Shelly1 (dry contact)
3. You search a little bit and use another relay with two contacts. Witch will be triggered by an shelly
2. What you mean dru contact? 2 shelly1 means 2 switches in app for same light
