I need to disconnect and connect a device with pulses from my shelly 1, I need to do an automation and use the input of my shelly 1 that is receiving a signal saying that the machine is in operation .. what happens when I add this scenario it’s like it didn’t exist because it ignores it .. I need to use INPUT Change ...
scenario does not work with input
- Shelly 1
Snowy#Cake#16730 -
9. November 2020 um 21:50 -
Erledigt
@klaus1993
Maybe you can explain what device (machine?) you want to connect the Shelly to and how you have wired it up to the Shelly. Is this device turned on and off only by the Shelly?
the important thing is the following, what is the reason for not putting INPUT STAT in the logic, everything else works, except that..
I need him to look at the second condition of the input change, and he ignores this rule
@klaus1993
The Shelly app‘s English is not so good
In your scene your saying
WHEN the Shelly is turned on (blue light/relay is activated) OR
WHEN the power usage is more than 1W
THEN turn on the Shelly
That doesn’t work or is strange. If it’s on why do you want to turn it on? What do you want to do with the scene?
so what app should i use?
Alles anzeigen@klaus1993
That doesn’t work
it does not work because the input is turned off, and the condition is met.
Dieses Thema enthält 13 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
