No Web interface and Unable to connect to WIFI in client mode
  • Hi Support,
    I have a brand new Shelly1PM to add to my various Existing Shellys (1's and 1PM's)
    But, when connecting to it via its own AP, (http://192.168.33.1) I don't get a webpage, rather I get the status and power usage JSON printed to the screen instead.
    Never mind, I'm a computer programmer and can use HTTP REST calls manually, so I'll try that instead.
    However, Even using the rest interface, I cannot get the Shelly1PM to connect to my Wifi network.
    A call to /wifi_scan lists my WIFI SSID correctly, so the shelly can see the WIFI network.
    A call to /status/sta?ssid=MY_SSID&key=MY_WIFI_PASSWORD&enabled=1&ipv4_method=dhcp
    Yields the following result.
    I.e. it doesn't even try to connect to my WIFI.
    How can I go about forcing the Shelly1PM into Wifi client mode?
    Thanks.
    Ash
  • maybe those devices are in developer test mode.. try this URL
    http://192.168.33.1/settings/developer?selftest_done=1
  • Finally got it sorted out.
    Had to power it off and on again; push the reset button until it flashed (about 10 seconds); then run the URL above. Came back working on a reboot of the device.
    Perhaps somehow it left the factory like that,,,, dunno
