Shelly 1 with automatic gate
  • Unfortunately my spanish is a bit rusty but aslong as u hook up your shelly Outputs to the repsective Inputs on the controller board for opening and closing and then setting up your app or UI to have the right Shelly O to trigger the right function on the controller you should be fine. But u need a Shelly 2.5 for this. Shelly 1 can only do 1 state. You need two as you want to open and close the gate.
    Or you can use two shelly 1 but setup in app will be more difficult as you will habve 2 buttons, one to open and one to close instead of one doing both
    If you can get an englisch schematic for the controller would help aswell
    Also I see alot of 24V so make sure you have the jumper in the right spot
  • @vitorfg
    I would take 2x Shelly1 and 1x DW2. You of course need a good WLAN at the gate!
    Suggest you power both Shelly 1 from 240V supply you have coming in to you device - check phase and neutral !!! (L and N on Shelly)
    Opening: connect first I on Shelly to Automatic External terminal 1 and O on Shelly to terminal 3 (can be other way also)
    Closing: connect second Shelly to Automatic External terminal 1 and O on Shelly to terminal 4
    SW on Shelly is not used!
    Set timer on both Shellys to automatic off after 2 secs
    You need the DW2 to check if the gate is really closed!
    Using terminals 1 (I) and 5 (O) should be investigated (potential for open/close with one Shelly).
    2 Mal editiert, zuletzt von peterc (9. November 2020 um 09:48)
