Action not executing
  • I have entered the URL http;//192,168.0.191/relay/1?turn=toggle under the Action/Button 2 Switched On URL (and enabled it)
    The IP address refers to another Shelly DImmer 2 activating a LED light. This LED works normal with the connected dimmer. (using the connected button, the app or the web interface)
    The button 2 is a push button.
    I can try whatever I want, but pusching button 2 long or short, one time or repeatedly, it does not switch the LED on or off.
    I have tried by enabling the action under Button 2 Long Pressed URL and Button 2 Short Pressed URL, but these actions fail to save under button 2 (see other topic on this forum)
    Can anyone provide advise how to solve this?
    Thanks
  • I have the same problem. Someone in another thread suggested to reboot the Shelly after defining the action but this has not worked for me.
    I have opened a support ticket with Shelly and they replied that they suspect a firmware issue but I haven't received further updates.
    The IP address refers to another Shelly DImmer 2 activating a LED light. ...
    Your syntax is false.
    To toggle a dimmer,you have to use:
    http://192.168.0.191/light/0?turn=toggle
    Have fun. :)
    Hello Mark. Please provide the feedback and resolution offered by Shelly, if you receive one.
    Thanks
