Shelly Dimmer 2 //Automatic switching off
  • Hello all,
    Just new on this forum and with shelly products.
    Have installed the shelly dimmer 2 behind pulse button and all working including callibration.
    After switching on the dimmer from the app after 2 minutes it is automatic going off. ( lights and also on the app the buttom)
    Anybody have a solution for that.
    grtz Danny
  • Hi Danny,
    Few questions:
    1. How many lights are you dimming?
    2. What is the combined power usage of the lights in watts?
    I have had similar issues, my dimmer got too hot because I had too many lights on it.
  • Hi,
    Thanks for your fast reply.
    I found it i had 6 x 50watt GU10 hooked up and that is to much as you say.
    Connected the shelly dimmer 2 to other lamp and no problem.
    Will replace lamps with 3,5 or 5 watt led .
    thanks for your help.
    kind regards,
  • Been there, done that! :D
    BTW: When you connect the led lights, with most of them it works best if you setup the dimmer as trailing edge.
    Good luck!
