Shelly 1 - Physical or External Switch not working
  • Hello Everyone,
    I have connected the Shelly 1 perfectly as per the manual, I'm able to On/Off through the app, however the physical switch does not work anymore now. Wether device is on or off the physical switch does not toggle anything and I have to use the app itself. Is there any solution ?
  • I tried all modes, even edgemode its still not working :(
    Also Button Type - When i select Edge switch - I get an error cannot select Edge switch when default mode is set to Switch
    Einmal editiert, zuletzt von Steep#Forest#17281 (30. Oktober 2020 um 07:52)
  • same for me , switching by the app always work but nothing happen when i use SW relay , i have done many factory reset for nothing ! i think my Shelly 1 is dead ? i have ordered new one .....
  • Hi,
    is there a small light inside your switch?
    How did you connect the Shelly?
    Phase L -> Shelly L
    Neutral -> Shelly N
    Phase L -> Switch -> Shelly SW
    What is the setting in "Power on default mode"?
    Is your switch a push button or a switch with on/off position?
    best regards
    Viele Grüße,
    Wolfgang
