Ligts not dimming and button doesn't work
  • Hi!
    I just installed my first Dimmer but I'm having some trouble.
    The dimmer is connected with a single switch according to the manual. The switch is a standard rocker switch with an added spring to make it momentary.
    It is connected to the WiFi and added to the app. I have done a calibration and I am able to turn the light on and off from there.
    The first problem is that dimming doesn't work, the light turn off as soon as I go below 100%. I have tried with 3 different bulbs, all dimmable, two of them were LED.
    The second problem is the switch. If the lights are ON and i push the switch they turn off. If I push the switch again nothing happens. The only way to turn on the lights is through the app.
    Does anyone have any idea of what could be wrong?
