Hi !
I got a shelly dimmer 2 days ago and installed it. It works well so far. However, there is one little thing that seems like a software bug to me:
I have my shelly dimmer 2 connected like in fig 2, "no neutral wiring". I'm using 1.8.5, I upgraded immediately when I installed the dimmer so I don't know if the issue also happenes with older firmwares. I think 1.7.1 or so was installed out of the box. I don't remember exactly anymore.
I have 50 Hz, 230 V. There a 100 W old bulbs connected and I calibrated with leading edge.
Now the issue:
When I hit the switch for a short time, it fades the light on to the brigthness it was on the last time I turend it off. If I hit it again for a short time it fades back to off. This is fine.
However, if the switch is in off and I hit the switch longed, it starts dimming the light towards bright. When I release the button it stops at the current brightness. If now, I hit the buttne again for ashort time to turn the light off, it switches the light off immediately. It skips the fading. I can reproduces this 100 % of the time.
Is this the right place to report this? If not, where should I put this instead?
In case this behaviour is intended for some reason, I'ld like to hear the reasoning behind it.
Thank you very much ![]()
