Energy consumption - no cloud
  • Hello,
    I just got my first Shell 1PM and it is work now for my heater. Now I want to monitor my energy consumption, but won't to use cloud, but just MQTT. So I have my topics in my MQTT broker, but there is no something, that I need. I want to put in mySQL consumption on each 5 minutes and after that I will do my calculations. Can you give me a clue , how can I get this information.
  • Maybe you can extract the values from the http://<ip_of_device>/status JSON. Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.
    25x 1PM, 4x 1L, 68x 2.5, 10x I3, 3x DIM, 2x H&T, 2x Flood, 2x RGBW
    Hello topche,
    WELCOME TO THE FORUM
    If you want to record the energy consumption values from a Shelly offline from the cloud then you have to do the following things:
    • enter a valid local ntp-server address
    • enter geo location settings, but don't set the checkmark for auto geo location detection
    And be aware that after every reboot or powerloss of the Shelly the energy counter will be set to zero again. So you need to cover this by your overall system.
    Grüße Bernd
    Mein "Smarthome":
  • Hello topche,
    Thank you Guzz
    You talking to do like that:
  • Can i change time of MQTT reporting. I need to have message on each one minute, but not on each 5 minutes.
