Shelly1 without N-conductor on One-Way switch
  • Hello everybody,
    I have an issue in order to install my new Shelly 1 in the flat where I`m leaving. The flat is in an old building around 60/70 and is located in Germany. I`m not sure if the cable green-yellow is my N-Conductor (from plug) in order to grab it and insert it in my Shelly.
    Can you please help me with this matter?
    2 Mal editiert, zuletzt von adrian (21. Oktober 2020 um 15:00)
  • I have installed the Shelly and linked the green-yellow cable to N from Shelly, everything is working as designed and expected.
    Einmal editiert, zuletzt von adrian (22. Oktober 2020 um 08:23)
