- Offizieller Beitrag
How do I create a new topic, a new post or ask a question here in the forum?
1. Select the FORUM tab in the left-hand side column.
2. Select subcategory, here e.g. SHELLY SUPPORT GERMAN, select the appropriate post / topic, here e.g. the corresponding Shelly:
3. Now click on "+ Create Thread" on the respective opened page in the upper area:
4. In order to CREATE a THEME, some additional information have to be entered:
Thread Status:
- Default - to use for "normal" use
- Pinned - is reserved for moderators and administrators. Subject remains top priority in the respective subcategory -> important topic
- Announcement - is reserved for moderators and administrators to announce firmware updates or Shelly updates
Informations:
- Select language: German or English
- Title - short concise title question
- Tags - "Tags" / "Label" -> e.g. Shelly 1PM, WiFi, Alexa, ...; Link to the corresponding keyword
- Publish topic at a later date:
- If the topic / contribution can not be fully summarized due to complexity, you can check the box here. After completion, remove the hook.
- Optionally, you can set a date here for which the topic / post should be published automatically.
5. Message
In the lower text field, the topic / the post / question can now be created.
6. Publish:
- PREVIEW - Before you publish the topic / the contribution you can use the PREVIEW and check your thread .
- Submit - Click Submit to post.
Good luck and have fun in the forum!![]()
(This is a translation of the original, german thread by SparkyMaster , thanks Axel.)
