Lights won't turn off after switching them off in Shelly App.
  • Hi Guys and Dolls,
    I am kind of new here so don't be too hard on me. :)
    I've bought a shelly dimmer 2 and installed it. I did update the firmware and calibrated the thing, but i can't manage to turn the lights off using the app. After i connected the power, the light is on and stays on.
    Even when the Shelly app tells me the light it off, it actually is still 'on'. And it still a little bit dimmable, but won't go out. The only way to turn the light of is too unplug the power wire N.
    Something tells me the Shelly Dimmer 2 is broken, but maybe you can help me?
    Look forward to your reactions.
    William
    Einmal editiert, zuletzt von Morning#Bread#15452 (7. Oktober 2020 um 15:02)
  • SparkyMaster 7. Oktober 2020 um 14:42
    Hat das Label von Shelly Dimmer auf Shelly Dimmer 2 geändert.
  • Hello,
    what was the solution? I am facing the same problem since i updated the device to latest firmware. After every firmwareupdate, the device is getting worse and worse unfortunately.
    I am running it in white mode btw, using the app as well. Not possible to switch off the lights completely, as they will always remain at ~5 % power....
    This is so rediculous...
    Any solution but changing to another controller?
