Shelly Dimmer 2 Firmware
  • Hello,
    I recently purchased a Shelly Dimmer 2 thinking it would be supported by Tasmota. It turns out that some code is in testing but not fully baked. Can someone send me a URL the original factory firmware for the Shelly Dimmer 2 so that I can reflash?
    Many thanks,
    Mark
  • Following this last post, I managed to pull the SHDM-2.zip file from this portal although it was not straight forward. For some reason, I needed to put in my public IP address to get the file before it would give me a compound URL from which I could figure out the file URL.
    Anyway, contents of the dimmer-I51-1.0 zip contains 4 bin files and a manifest.json file. I assume that this contains all the data needed for an OTA reload.
    For manual reloads, can anyone point me to a list of esptool commands (or the like) to reload the Shelly to its factory state? I assume that each of these bin files need to be added to different parts of memory.
    Thanks,
    Mark
  • Hi
    Tell me, did you manage to download the original firmware to the module? I have the same problem.
  • Thank you very much. Within a few minutes I uploaded the original firmware without any problems.
  • Dieses Thema enthält 33 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
