Minimum wattage for multiple LEDs
  • Hello,
    I have 5 LED bulbs with 6.5W each in my lighting fixture. Spec'd minimum wattage for Dimmer 2 is 10W. My bulbs flicker with 25Hz when I switch them on. When I start calibration, the dimmer eventually crashes with the mysterious "Error 4". I've set the Dimmer to "Trailing edge", which should be correct.
    Is there some hidden setting I could try to make it work, or do I just have to buy bulbs with a higher wattage?
    Thanks in advance for any hints!
  • Hi, thank you for your reply!
    I do have dimmable LED bulbs. Firmware is 20200904-094614/v1.8.4, which should be the latest one if I'm not mistaken. So I'm kinda stumped why my setup doesn't work as expected.
